pic.1
pic.2
pic.3
pic.4
![Screenshot 2022-12-23 133831.jpg Screenshot 2022-12-23 133831.jpg](https://forums.autodesk.com/t5/image/serverpage/image-id/1155672i8173DAB5A3C6046C/image-size/large?v=v2&px=999)
pic. 5
Well, now i have a problem about connecting beam to column (web side) because when using command same as the side that beam connect to column (pic.5 flange side) i.e. i want shop drawing to have. all the same size so that it will be the same standard if you don't understand Please open my DWG file to check.
From Figure 1 you can see that I have highlighted the column because connecting the beam to the column on the flange side using the "I Bracing Splice Full Gusset Simple" command is incorrect. I absolutely want the form to be connected it's like the 2nd picture, but I don't know how to do it. So i have to create another column that overlaps each other. to come as a reference point in order to connect to the flange side
So the question is, how can I create a connection like in Figure 2 without having to create a dummy column?
The 3rd and 4th pictures have the same problems as the 1st and 2nd pictures.
