Does anyone have a strategy for creating a flattened pipe and having it display "acceptably" within a part drawing?
no chance to realize it with Advance Steel.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
The nearest you can do is make a special part and weld it to the end of your tube. Then use the assembly drawing.
Aleck Giles, Structures Consultant, Graitec
A piston can be made to the shape and produce any required quantity easily
