Hi
Where is the camera filtering??
Solved by DumitruBerteanu. Go to Solution.
The Advance Steel Camera filtering that you highlight will select any Advance Steel camera objects found in the model, that are created with the following two commands :
In the picture from your post I can see a different Camera object (Created by AutoCAD probably), object that is not subject of this filter, which tries to filter out only the objects "ASTXCAMERA " from your model.
hi
Thank you the answer
