camera filtering AS
GHASEM_ARIYANI
camera filtering AS
GHASEM_ARIYANI
Hi
  Where is the camera filtering??
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
DumitruBerteanu
The Advance Steel Camera filtering that you highlight will select any Advance Steel camera objects found in the model, that are created with the following two commands :
In the picture from your post I can see a different Camera object (Created by AutoCAD probably), object that is not subject of this filter, which tries to filter out only the objects "ASTXCAMERA " from your model.
Dumitru Berteanu
Product Owner
GHASEM_ARIYANI
hi
Thank you the answer
