Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
camera filtering AS
2 REPLIES 2
GHASEM_ARIYANI
423 Views, 2 Replies
camera filtering AS
Hi
  Where is the camera filtering??
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
2 REPLIES 2
The Advance Steel Camera filtering that you highlight will select any Advance Steel camera objects found in the model, that are created with the following two commands :
In the picture from your post I can see a different Camera object (Created by AutoCAD probably), object that is not subject of this filter, which tries to filter out only the objects "ASTXCAMERA " from your model.
Dumitru Berteanu
Product Owner
hi
Thank you the answer
