Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
AS MODEL VERY SLOW - OFTEN Advance steel HUNG
5 REPLIES 5
desigan2015
468 Views, 5 Replies
desigan2015
Dear All.
my model size is 17 MB .Roof with z - purlins  and more spilce connections.
it is too slow and often hung. what are necessary steps i have to do when i do big model to avoid the hung and work fast . please give me some  suggestion .
I have created lot of model view , is this reason for the slow and hung .
Dear All.
5 REPLIES 5
sdonohoedesign
For a model of this size / complexity the 2D wireframe visual style will be slow.
Try the 'fast shaded' visual style.  You should see a big improvement.
vuongbui.nuce
in reply to: desigan2015
vuongbui.nuce
@desigan2015 , use this command. purge all anything you dont need.
desigan2015
@sdonohoedesign  fast shaded ?
sdonohoedesign
I don't have AS2023, but I believe the 'out of the box' model template file includes a fast shaded visual style.
You can copy visual styles between drawings using the explorer (ctrl+2)
If you don't have this, you can configure your current drawing visual style as per Graitec recommendations
Optimise Graphics Performance In Advance Steel To Navigate Large Models Effectively | GRAITEC
Steve
Steve
AleckGiles
AleckGiles
The Conceptual visual style is the worst / slowest performing style of all. See my blog here and here.
If you are using As2023 or higher just switch to Shaded or Shaded with Edges visual style. Then if the menu does not say "(FAST)" next to it type FASTSHADEMODE 1 to turn it on. It overrides your settings to something it can work with.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
LinkedIn
