I found these objects in my model today. Not sure how they were created or why they exist.
The Objects are called ASTXUSERDEFINEDPOINT
I am curious what they are and how they are used by Advance Steel.
Solved by Rob_Merriman. Go to Solution.
These come from macros where you are asked to click a point, for example the railing macro where it asks for the start / end point. The stair macro, ladder, purlin macro all have them too. Any macro where the user is defining a point this is what they are.
It could have also come from a custom connection where you have Beam/Point as an input.
Rob Merriman, AEC Technical Lead, Graitec
HI,
The points are not "Physical" objects so, no, they are not available for dimensioning or anything else. They just control the joint.
Aleck Giles, Structures Consultant, Graitec
HI,
