Advance Steel custom commands-share your ideas
acbsdesign
Mentor Mentor
Message 1 of 815
acbsdesign
It will be nice to learn more about custom commands / combination of Autocad and Advance Steel commands improving productivity.
To colleagues willing to share-Thank you.
Here is a tiny example:
"Hide parts with identical numbers"-used when parts are detailed using drawings styles.
^C^C_AstM5equalpartsMarkSame \;AstM4CommSelectMarkedObjects ;_AstM4SwitchReprMode off
And another one:
"Hide Similar Advance Steel Objects":
^C^C_SelectSimilar \;_AstM4SwitchReprMode off
Ilko Dimitrov
ACBS
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
Accepted solutions (126)
Replies (814)
Message 41 of 815
Yep 😄 but with shortcuts! 😄
Message 42 of 815
acbsdesign
@Anonymous
Any suggestions about Toolbar Icon?
I am using yours for the fillet with R=0, it is great looking consistent with others similar.
Message 43 of 815
acbsdesign
@Anonymous
This is rotating UCS around X-axis, we have it already included in AS as Sebastian pointed, am I missing something?
Message 44 of 815
@acbsdesign wrote:
@Anonymous
I made the attached, what do you think?
I don't know how to make the inverse icon though?
All the standard icons have an inverse that is used for the light theme, and this is the one that the right click context menu uses, so my custom icons look awful in it, hence the RotateAli.bmp being blue not white, RotateAligned.bmp, which i prefer, was invisible in the context menu.
Does anyone know how to solve this?
Message 45 of 815
Sebastian_Eiche
in my opinion the easiest way to use such icons is to take the original and change them. The pics which you see in the Cui are exportable so it should be easy to invert the original one or do I missunderstand something? Also it's possible to edit the pic and use "save as" to create a new one
To create a inverse pic, you use the free software paint.net --> there's a command for "invert color"
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 46 of 815
acbsdesign
It looks great!
I am using it.
Thank you.
Message 47 of 815
My white one was adapted from the original, but I use the dark theme so that's the image it gave me to export. I don't know how to create a custom for both so it uses the dark one for the toolbar and the light one for the context menu.
Message 48 of 815
Sebastian_Eiche
maybe for the manual weld placement:
*^C^C_AstM4WeldSeam;POINT
Way to use:
  • use the normal weld command and set the weld you want to define often
  • then use the command *^C^C_AstM4WeldSeam;POINT
  • the '*' will be used to never stop the weld command, so the user could set many weld with the same settings
  • ESC will end the command
Sebastian Eiche
Message 49 of 815
That is awesome!
I've always hated how you can't just press enter to repeat the weld point command!
Icon attached, not the best though, was hoping the repeated pink points would be clearer.
Any other icon suggestions?
Message 50 of 815
@Anonymous wrote:
That is awesome!
Actually attached icon now!
Message 51 of 815
Sebastian_Eiche
maybe like this...
Sebastian Eiche
Message 52 of 815
alickomay
is it just me or has this thread added more value then the last few years of updates
dose any one have a command for hide all bolts /welds /cuts-features/ acad lines
or alternative way
show only as beams an plates
Message 53 of 815
Sebastian_Eiche
not tested, I'm not in the office, but should work
^C^C_AstM4SelectObjectByName;ASTBEAM,ASTPLATE;_AstM10ViewSelObjects;OBJECTS;_AstM4SelectObjectByName;ASTBEAM,ASTPLATE;_AstM4SwitchReprMode;default
Sebastian Eiche
Message 54 of 815
acbsdesign
@alickomay
If all the knowledge / tips / tricks / custom commands etc of AS users are shared, we all will benefit. I hope a guy in Florida with "lateral" thinking (I am in a few miles from him today/tomorrow, may be we can have an October fest test or something) will join the thread and share more of his ideas.
Message 55 of 815
acbsdesign
Tested it, it needed an ESC mimic at the end, and it works great:
^C^C_AstM4SelectObjectByName;ASTBEAM,ASTPLATE;_AstM10ViewSelObjects;OBJECTS;_AstM4SelectObjectByName;ASTBEAM,ASTPLATE;_AstM4SwitchReprMode;default;graphscr;redraw;
Any toolbars suggestions are welcome. Thank you.
Message 56 of 815
That works.
Great command, added to my quick access toolbar.
Icon attached
Message 57 of 815
acbsdesign
Simple and nice.
Thank you.
Message 58 of 815
Masibanda-CE
This is the greatest thread of all time!
I've added a few CCs to my shortcut menus. Sebastian's "point weld" has been the star and I added it to my DEFAULT so it's at the ready, but the others I've added to EDIT and they appear as seen below. Does anyone know how to place them in that "Advance Steel" area, I can't figure out where it is.
Message 59 of 815
acbsdesign
Similar to the procedure described in one of the first posts, type CUI, in Shortcut menus-go to Default or Edit, and drag the command to the desired location.
Message 60 of 815
Masibanda-CE
Ilko, the question is; where exactly is the shortcut menu that is specific to AS objects being selected? You mention DEFAULT & EDIT, and I've also looked in COMMAND as well as many others without success. In my example, I have placed some CCs within the EDIT shortcut menu. Therefore they show up when any object is selected (lines, circles, etc.). Where is the shortcut menu that relates to the AS objects? I've been through the partial CUIs and also the all the out-of-the-box shortcut menus that look promising, but I can't find the specific AS shortcut menu.
Cheers,
Gary
