Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Advance Steel custom commands-share your ideas
acbsdesign
Mentor Mentor
Message 1 of 815
acbsdesign
It will be nice to learn more about custom commands / combination of Autocad and Advance Steel commands improving productivity.
To colleagues willing to share-Thank you.
Here is a tiny example:
"Hide parts with identical numbers"-used when parts are detailed using drawings styles.
^C^C_AstM5equalpartsMarkSame \;AstM4CommSelectMarkedObjects ;_AstM4SwitchReprMode off
And another one:
"Hide Similar Advance Steel Objects":
^C^C_SelectSimilar \;_AstM4SwitchReprMode off
Ilko Dimitrov
ACBS
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
Accepted solutions (126)
Replies (814)
Message 401 of 815
Hi @acbsdesign ,
I have been using a space bar since 1994 to interrupt, terminate or repeat the command 😉
It is a natural method, my thumb finds this key very quickly 😁
Message 402 of 815
acbsdesign
@Anonymous wrote:
Hi @acbsdesign ,
@Anonymous
Thank you for sharing 🙂
It is just F2 is close to ESC and this is making things easier on my end.
I did stick a thick pad on F2 to get used to it, it takes appr. 21 days to develop such a habit, scientists say.
Whatever we are used to, the most important is the result at 5 pm.
Keep posting.
Message 403 of 815
dave_conibear
Hi Ilko
I'm having some trouble understanding this command.......
I'm sure I have the correct macro.....^C^C_rotate;\r;\\\;;
When I select the member, then the base point........I choose "R" for reference and hit return, then the command exits.
In my simple example, I want to move the beam and align to the line
Message 404 of 815
acbsdesign
@dave_conibear wrote:
Hi Ilko
Hi Dave,
This is the macro I  am using: ^C^C_rotate \r;\\\;;
Select the beam first.
This is a screencast how it works (it is showing two commands, but you can get the idea):
Screencast
Basepoint wouldn't move, it is "nailed", after that choose 1st ref. point, choose 2nd reference point (this will define the orientation)
If I have to move something and rotate at the same time, best way to do it is probably by using the align command, second destination point to first destination point - distance has to be always greater than the distance between first and second points.
This is a short screencast me parking a barge along a pier 🙂 :
(2D should be on)
Move and Align
Regards.
Message 405 of 815
dave_conibear
Top man...........I have it...........thanks Ilko
Message 406 of 815
acbsdesign
Multileader block / call-out, file attached.
Right-click and slide in ACAD tool palettes.
Screencast 1
Screencast 2
Decided to put it here, hopefully, someone may find it useful.
Message 407 of 815
acbsdesign
So what I have found useful about this command-It works same as Advance Copy-it copies even the joint box.
I will give an example - Copy headers with connections at multiple door frames, same as advance copy, but by selecting random distances, or any member that can be used with 'copy with adjustments'  command - this command is actually shortening modeling time if we get used to it:
Mark and select shop attached objects and connection means
Mark and select connected objects in shop, mark and select connection means-Ability to quick Advance Copy with joint boxes included
^C^C_AstM4SwitchReprMode MAINSTRUCTURE \;_AstM4CommSelectMarkedObjects;_AstM4CommMarkConnMeans;_AstM4CommSelectMarkedObjects;
I will add this as a solution, it is helpful.
Any other ideas are welcome.
It saved me at least 8-12 hours of work on another project doing a massive design change.
Message 408 of 815
Jonathan3891
I recently had a need for a fillet command so I created one myself.
;Fillet Members
(defun c:AstFilletMember (/ Obj1 Obj2)
  (setq Obj1 (entsel "\nSelect first member")
	Obj2 (entsel "\nSelect second member")
  (command "_AstM9CommTrimExtend" "" "S" Obj1 "" Obj2 "" "")
  (command "_AstM9CommTrimExtend" "" "S" Obj2 "" Obj1 "" "")
  (princ)
Jonathan Norton
Blog | Linkedin
Message 409 of 815
acbsdesign
@Jonathan3891
Can you please make a short screencast when you get a minute?
Thank you.
Have a great afternoon.
Message 410 of 815
Jonathan3891
Its similar to AutoCAD's fillet command, but works with Advance Steel members.
https://autode.sk/3fc8xfD
Jonathan Norton
Blog | Linkedin
Message 411 of 815
Jonathan3891
I had some time to rewrite it and include some filters.
It still works the same as the screen cast I posted above.
(defun c:AstFilletMember (/ ent1 ent2)
  (setq ent1 (entsel "\nSelect first member: "))
  (if (or (null ent1)
	  (/= (cdr (assoc 0 (entget (car ent1)))) "ASTBEAM")
    (while (or (null ent1)
      (princ "\nSelect first member: ")
    );while
  );if
  (setq ent2 (entsel "\nSelect second member: "))
  (if (or (null ent2)
	  (/= (cdr (assoc 0 (entget (car ent2)))) "ASTBEAM")
    (while (or (null ent2)
      (princ "\nSelect second member: ")
    );while
  );if
  (command "_AstM9CommTrimExtend" "" "S" ent1 "" ent2 "" "")
  (command "_AstM9CommTrimExtend" "" "S" ent2 "" ent1 "" "")
  (princ)
Jonathan Norton
Blog | Linkedin
Message 412 of 815
acbsdesign
Thank you for sharing,
This is a great command.
Keep posting.
Message 413 of 815
acbsdesign
Hi everyone,
Something that may be useful when we have design calculations for connections done by others,
and if we need to reference a shear plate or angle where is this connection located within the calc's package.
Then if we enter connection ID in Joint Name, shear plate label can display the joint name, if no joint name, it will display normal label.
Script if a joint has a name, then display joint name:
%%script(JointName= "%JointName": NoJointName = "None": Compare = StrComp(JointName, NoJointName, 1): If Compare <> 0 then appendstring ""&JointName&"")
Happy Holidays.
Message 414 of 815
HenrykKuźma8230
Observer
Observer
Can you reupload iconpack?
Message 415 of 815
acbsdesign
Not a custom command, but may be it is worth sharing:
Custom Connections Girts to HSS columns
There are two connections (file attached, left and right) for HSS12x12 and two for HSS10x10.
Regards.
Message 416 of 815
SanjoyNath
Dear Experts,
We need a process to get the log of all change logs (Geometry , features, roles or rules responsible for) prenumber change and post number change for every single part and also for assemblies in the whole life cycle of the project.
Is there any way to get these?
   Currently we are storing these data in external databases through numbering scripts in AstorKernel.This hangs several times when used for big projects or for multi users over network.
Sanjoy Nath
BIM Manager And Digital Lead (Structures Online)
BOOST, AR , VR ,EPM,IFC API,PDF API , CAD API ,Revit API , Advance Steel API
Founder of Geometrifying Trigonometry(C)
Message 417 of 815
SanjoyNath
Dear Experts,
Previously AstorAutomations with VBA helped us in 32 bit systems. That stopped working in 64 bit versions since tlb file for numbering scripts and DPM scripts are still 32 bit
That tlb helped us to do these with vba. implementing c# , compiling and closing Advance steel every time in every systems and then putting addins is tedious and users get annoyed.
Atleast if vba is not working (in 64 bit then give facilities of lisp for Advance steel or on the fly macro facility of c# AS IN REVIT ) such that we can run c# macros without closing Advance steel everytimes
Sanjoy Nath
Message 418 of 815
SanjoyNath
Dear Experts,
I think these are available shortcuts hidden inside ribbons or in DIESEL objects
In the Attached file you will get all the existing commands upto version 2019 of Advance Steel
I have attached the list
(Message Cannot Exceed 100000 characters)
Sanjoy Nath
Message 419 of 815
acbsdesign
Does anyone know how to create a custom command:
"Delete all MP, SP, and Preliminary Numbers"
Thank you.
Message 420 of 815
Sebastian_Eiche
should be something like this:
^C^C_AstM5EqualPartsSwitchSingle;_AstM5equalpartsReset;_AstM5EqualPartsSwitchMain;select;p; ;_AstM5equalpartsReset;_AstM5EqualPartsSwitchPreliminary;select;p; ;_AstM5equalpartsReset;
but then it's about selected elements, maybe a select "all" would be better?
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
