Advance Steel custom commands-share your ideas
acbsdesign
Mentor Mentor
Message 1 of 815
acbsdesign
It will be nice to learn more about custom commands / combination of Autocad and Advance Steel commands improving productivity.
To colleagues willing to share-Thank you.
Here is a tiny example:
"Hide parts with identical numbers"-used when parts are detailed using drawings styles.
^C^C_AstM5equalpartsMarkSame \;AstM4CommSelectMarkedObjects ;_AstM4SwitchReprMode off
And another one:
"Hide Similar Advance Steel Objects":
^C^C_SelectSimilar \;_AstM4SwitchReprMode off
Ilko Dimitrov
ACBS
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
Accepted solutions (126)
Replies (814)
Message 341 of 815
acbsdesign
No, it doesn't work with space between END IF.
Thank you.
Message 342 of 815
Sebastian_Eiche
Really? I tested it yesterday and with End If I got not error.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 343 of 815
acbsdesign
no, if this is the script below, it is not working:
%%script(CH = "%CamberHeight": NOTE = "<C=%CamberHeight>": If CH <> Empty then appendstring NOTE END IF)
The top beam has camber
The bottom beam is without camber
If we update detail it works fine, if we manipulate from detail properties-adding default views - it would trigger the messages to pop up.
This is the screencast:
https://knowledge.autodesk.com/community/screencast/6a0fa410-0f65-4bdf-a996-640135677dfe
Thank you.
Message 344 of 815
Sebastian_Eiche
hmm, the question is: what is different to my test?
I copy the script again from your post and create a detail and set the views...
Screencast
Sebastian Eiche
Message 345 of 815
acbsdesign
Thank you for the screencast and for your time.
I have to find out what is the difference, why yours works fine and mine doesn't.
Message 346 of 815
acbsdesign
Hi everyone,
Not a custom command, but I found a piece of a tiny small software saving time with the everyday back-ups,
SyncFolder
Option to Synch and Copy, also-scheduling when to be performed, or manual etc.
I find it a time saver and decided to put it here.
Message 347 of 815
Hi Ilko,
very nice recommendation 😉. Is that better than standard Windows synchronization?
Message 348 of 815
acbsdesign
Hi Karel,
I have never used the Windows synchronization, I cannot compare.
But this one is really good.
Regards
Message 349 of 815
markhubrich
Ever used RoboCopy ? It's already on your system and it's extremely powerful.
...and fix the kiss export issues.
Message 350 of 815
acbsdesign
Never used it, have you tried SyncFolder?
First software to install when resetting or setting up a workstation.
Message 351 of 815
lim.wendy
Thank you all for sharing all these great ideas and tips! It's truly heartening to see people coming together to share tips and best practices. 🙂
“The essence of community, its heart and soul, is the non-monetary exchange of value; things we do and share because we care for others, and for the good of the place.” ― Dee Hock
Thank you, @Sebastian_Eiche for bringing this to my attention. I've pinned this discussion at the top so others can easily find it. 🙂
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Message 352 of 815
acbsdesign
@lim.wendy
Thank you for your support, I hope everyone will benefit from sharing their knowledge and experience here.
@Sebastian_Eiche
You definitely have dinner on me, thank you for being the hard-working and always helping Sebastian.
Have a great weekend.
Message 353 of 815
Masibanda-CE
I was trying to find a way to create a process that will ONLY select loose parts but can't quite get it. In the mean time I added this little "compound command" to the tool pallet that will mark loose parts, select them, and then unmark them:
^C^C_AstM4CommStandaloneParts _AstM4CommSelectMarkedObjects _AstM4CommUnmarkObjects
Message 354 of 815
Sebastian_Eiche
be careful with this command, I would add an "unmark" in the beginning. If you already have marked object, the command for "mark standaloneparts" will not clean up the marking before mark the standalone parts. So this could be dangerous
Sebastian Eiche
Message 355 of 815
acbsdesign
For users sharing model views with fabricators, engineers, and erectors:
Shared Views is good for 30 days unless the link is extended, not handy for projects having design changes and done in phases within 4-6-12 months period.
So I was searching for a way to have a model view shared with clients, and with the same link working after design changes, not expiring.
Once model is done, we upload it to Autodesk Drive and create a QR code using this site , save it as png file and place it on erection drawings somewhere near the title block.  It can be done in prototypes, or in PDF files-as a signature or stamp, placed on all sheets at once.
If we have design changes we simply upload a new version of the model, with the old link still working.
I hope this will be helpful.
Thank you @markhubrich  for the QR code generator idea.
Message 356 of 815
markhubrich
Your welcome @acbsdesign  😄
The main feature I like about Shared Views is ability to comment. I see Drive lets us measure now at least.
Message 357 of 815
markhubrich
Hmm 💡, check it out..  A QR Code ACAD app  I didn't try it yet but it could remove a few steps from the process.
Message 358 of 815
markhubrich
Actually this is pretty handy.
I'm sure we could embed a project attribute mtext into prototype and presto!!!
Message 359 of 815
acbsdesign
Mark,
Yes, it works great,
Thank you very much!!!
Message 360 of 815
markhubrich
It doesn't appear to work with attributes.
