A few commands I found to be useful, summarized and tested, icons attached as well:
Isolate Beams:
^C^C_AstM4SelectObjectByName;ASTBEAM;_AstM10ViewSelObjects;OBJECTS;_AstM4SelectObjectByName;ASTBEAM;_AstM4SwitchReprMode;default;graphscr;redraw;
Hide Beams
^C^C_AstM4SelectObjectByName;ASTBEAM;_AstM4SwitchReprMode off;_AstM4CommUnmarkObjects;graphscr;redraw;
Isolate plates:
^C^C_AstM4SelectObjectByName;ASTPLATE;_AstM10ViewSelObjects;OBJECTS;_AstM4SelectObjectByName;ASTPLATE;_AstM4SwitchReprMode;default;graphscr;redraw;
Hide Plates
^C^C_AstM4SelectObjectByName;ASTPLATE;_AstM4SwitchReprMode off;_AstM4CommUnmarkObjects;graphscr;redraw;
Isolate BENT BEAMS ^C^C_AstM4SelectObjectByName;ASTBENTBEAM;_AstM10ViewSelObjects;OBJECTS;_AstM4SelectObjectByName;ASTBENTBEAM;_AstM4SwitchReprMode;default;graphscr;redraw;
Isolate GRATING
^C^C_AstM4SelectObjectByName;ASTGRATING;_AstM10ViewSelObjects;OBJECTS;_AstM4SelectObjectByName;ASTGRATING;_AstM4SwitchReprMode;default;graphscr;redraw;
Hide GRATING
^C^C_AstM4SelectObjectByName;ASTGRATING;_AstM4SwitchReprMode off;_AstM4CommUnmarkObjects;graphscr;redraw;
Hide grids
^C^C_AstM4SelectObjectByName;ASTGRID;_AstM4SwitchReprMode off;_AstM4CommUnmarkObjects;graphscr;redraw;
Hide welds
^C^C_AstM4SelectObjectByName;ASTWELD;_AstM4SwitchReprMode off;_AstM4CommUnmarkObjects;graphscr;redraw;
Isolate bolts
^C^C_AstM4SelectObjectByName;ASTSCREWBOLTPATTERN; _AstM10ViewSelObjects OBJECTS
Hide bolts
^C^C_AstM4SelectObjectByName;ASTSCREWBOLTPATTERN;_AstM4SwitchReprMode off;_AstM4CommUnmarkObjects;graphscr;redraw;
Hide Model Views
^C^C_AstM4SelectObjectByName;ASTXMODELVIEW;_AstM4SwitchReprMode off;_AstM4CommUnmarkObjects;graphscr;redraw;
SELECT BEAMS AND SWITCH TO STANDARD REPRESENTATION:
^C^C_AstM4SelectObjectByName;ASTBEAM;_AstM4SwitchReprMode;default;graphscr;redraw;
SELECT PLATES AND SWITCH TO STANDARD REPRESENTATION:
^C^C_AstM4SelectObjectByName;ASTPLATE;_AstM4SwitchReprMode;default;graphscr;redraw;
Ribbon
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
