Advance Steel custom commands-share your ideas
acbsdesign
Mentor Mentor
Message 1 of 815
acbsdesign
It will be nice to learn more about custom commands / combination of Autocad and Advance Steel commands improving productivity.
To colleagues willing to share-Thank you.
Here is a tiny example:
"Hide parts with identical numbers"-used when parts are detailed using drawings styles.
^C^C_AstM5equalpartsMarkSame \;AstM4CommSelectMarkedObjects ;_AstM4SwitchReprMode off
And another one:
"Hide Similar Advance Steel Objects":
^C^C_SelectSimilar \;_AstM4SwitchReprMode off
Ilko Dimitrov
ACBS
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
Accepted solutions (126)
Replies (814)
Message 121 of 815
A further variation on Isolate Assembly to include any bolts or anchors attached to the assembly.
Isolate Assembly and all connection means (Clears Marking) (Select Object First)
_^C^C_AstM4CommUnmarkObjects;_AstM4SwitchReprMode MAINSTRUCTURE graphscr;redraw;_AstM4CommSelectMarkedObjects ;_AstM4CommMarkConnMeans graphscr;redraw;_AstM4CommSelectMarkedObjects ; _AstM10ViewSelObjects;;_AstM4CommUnmarkObjects;;;graphscr;redraw;
Can't seem to work out the variation where you can initiate the command before selecting the object though, so it's just a Select object first version I'm afraid.
Icon Attached
Message 122 of 815
acbsdesign
@Anonymous
Thank you for sharing.
Can you think about a command "Bring all AS dimensions to front"  - right click on dimensions+select similar+bring to front, maybe, couldn't make it work, being crazy busy.
And another one: "Hide detailed parts"
Message 123 of 815
@acbsdesign wrote:
@Anonymous
As Requested, works with any object type, also icon attached (icon suits the dark theme though so looks horrible in the right click menu I'm afraid).
Bring Similar Objects To Front
^C^C_SelectSimilar;^p_ai_draworder _Front ^P
Don't even know where to start with "Hide detailed parts" I'm afraid. It would be a very useful command though!
Message 124 of 815
Sebastian_Eiche
often discussed and many ideas to this issue. It's not possible with stock commands of Advance Steel and AutoCAD.
I think maybe by using the API commands, but not with stock commands
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 125 of 815
Light versions of icons for Fillet0 and Rotate Align attached.
Look better in the right click menu
Message 126 of 815
vuk.vukanic
@acbsdesign
@Anonymous
Bring to front similar with Action Recorder:
https://autode.sk/2CJYMmE
Easy things are not worth the effort
http://www.teamcad.rs
Message 127 of 815
@vuk.vukanic wrote:
@acbsdesign
@Anonymous
Smiley Surprised
I've never even tried that!
Can the Macros be shared?
Message 128 of 815
Sebastian_Eiche
why not filtering with a command for selecting the whole dimension:
^C^C_AstM4SelectObjectByName ASTXdimline,astxdimarc,astxdimdia
Sebastian Eiche
Message 129 of 815
vuk.vukanic
@Anonymous
Yes, they are stored in:
C:\Users\UserName\AppData\Roaming\Autodesk\Advance Steel 2019\R23.0\enu\Support\Actions
Just copy folder to another comp and the commands will be available.
PS take a look at post 108 on page 6 of this thread. I attached a file with my shortcuts...
Message 130 of 815
Yes, below the full command for bringing specifically all AS Dims to the front
Bring All AS Dims to Front
^C^C_AstM4SelectObjectByName ASTXdimline,astxdimarc,astxdimdia;^p_ai_draworder _Front ^P
Message 131 of 815
Sorry, I'd missed that post somehow.
That looks very useful!
I've added the "Manage" tab to my AS Ribbon. Can't wait to have a mess about with it!
Message 132 of 815
Light and Dark Icons attached
Message 133 of 815
acbsdesign
@vuk.vukanic wrote:
@acbsdesign
@Anonymous
@vuk.vukanic
Great, Thank you.
Message 134 of 815
acbsdesign
I small tip, used for just about anything that needs to be handy to be inserted in a dwg.
Convert text, shape, or make a custom hatch, or dynamic block in a template dwg, convert to block (except hatch), right click on it, and drag it to ACAD palette. Ready to be used, a huge time saver for me:
https://autode.sk/2HYlKKq
Message 135 of 815
Adrian.Mangan
Thats great one Ilko.
Thank you
Message 136 of 815
Adrian.Mangan
@vuk.vukanic , thats fantastic, think i got it, haha, but I will get it, thank you so much.
Also thank you to everyone else in this thread @acbsdesign @Anonymous @Sebastian_Eiche @Masibanda-CE
All these tips will save me a lot of time, very excited, thank you so much everyone.
Sometimes I feel like I haven't time to get into learning things to make me better but I have been advised to learn at least 1 hour a day and it is paying off.
Message 137 of 815
acbsdesign
@Adrian.Mangan
Weird, but true-I thought when I switch to self-employed, I would have more time to customize etc.
It is the complete opposite.
Thank you, everyone, for contributing here.
Message 138 of 815
markhubrich
Call it a custom command or whatever you like but here's what I would like.
Allow decimal feet on Level Symbols. Also allow Level Symbols placed in the model to always face the view direction.
Example:
Xref loaded of Civil DWG to use for sidewalk elevation reference. Elevation points shown in decimal feet. Typ for Civil drawings.
Would be nice if I could read the Level Symbols in this view 🙂
...and fix the kiss export issues.
Message 139 of 815
acbsdesign
Example:
@markhubrich
Mark,
You have the Decimal level symbols now, in MT, filter Level, and Dwgs-labeling, General-modify the units.
Message 140 of 815
markhubrich
It only has decimal inches.
