Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Add new Plat Size
4 REPLIES 4
GHASEM_ARIYANI
542 Views, 4 Replies
Add new Plat Size
hi
How do I add size for Plate?
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
4 REPLIES 4
I think we need some clarification.  You are pointing to "Flat Bar".  AS treats Flat bar and plates differently.  Plates are more freeform and can be any length, width, and thickness.  Flat bars are treated the same as typical "Beams" such as angle, I-Beam, Channels, etc...  Are you trying to add a size to the Flat Bar section or do you need to make a special plate?
hi
The tool user section I solve the problem.
But there is a way to add to the list Flat?
ZHUKOV_ING
in reply to: GHASEM_ARIYANI
Try to insert the desired flat section in this table (for metric) or in EXT_AISC_Flat for Imperial...
GHASEM_ARIYANI
in reply to: ZHUKOV_ING
Hello
Thank you.
