hi
How do I add size for Plate?
Solved by ZHUKOV_ING. Go to Solution.
I think we need some clarification. You are pointing to "Flat Bar". AS treats Flat bar and plates differently. Plates are more freeform and can be any length, width, and thickness. Flat bars are treated the same as typical "Beams" such as angle, I-Beam, Channels, etc... Are you trying to add a size to the Flat Bar section or do you need to make a special plate?
hi
The tool user section I solve the problem.
But there is a way to add to the list Flat?
Try to insert the desired flat section in this table (for metric) or in EXT_AISC_Flat for Imperial...
Hello
Thank you.
