So after modeling a project and processing all dwgs. I realized I need to add more of a certain part.
Is there a way to copy a part and keep the same single part number without reprocessing or making a duplicate part dwg?
Solved by wtheron. Go to Solution.
It works but I realized I can't only have the new parts highlighted or else it puts the internal number on it.
When numbering, the original part must be selected as well.
We have coppied a mainpart (Assembly) several times with copy object part number in default checked.
We now want to change one of these assemblies but are stuck with the Main part number.
If we try to delete the main part number with only the assembly we want to change selected,
part number are deleted from all the original assemblies. Or if we change the number all change
even if the new part has been modified.
Can anyone help with the correct procedure please.
We would prefer not to have to change default setting any time we want to copy.
