Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
3 pipes joint
2 REPLIES 2
votuananhvungtau
578 Views, 2 Replies
3 pipes joint
I have a 3 pipes connection as below:Picture-1Picture-1
I use the Element Contour - Rule but it is created a understate - wrong profile as below:Picture-2Picture-2
Can anyone help me ?
Thank you so much !
2 REPLIES 2
this is working with element contour. I made a screencast for you: https://autode.sk/2AOAK9l
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Thank you so much Mr. Sebastian_Eiche, you are right !
Element Contour - UCS can do that. Element Contour - Rule only use for 2 pipe connection.
Technology Administrators
