I have a 3 pipes connection as below:
I use the Element Contour - Rule but it is created a understate - wrong profile as below:
Can anyone help me ?
Thank you so much !
Solved by Sebastian_Eiche. Go to Solution.
this is working with element contour. I made a screencast for you: https://autode.sk/2AOAK9l
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Thank you so much Mr. Sebastian_Eiche, you are right !
Element Contour - UCS can do that. Element Contour - Rule only use for 2 pipe connection.
