I have a 3 pipes connection as below:
I use the Element Contour - Rule but it is created a understate - wrong profile as below:
Can anyone help me ?
Thank you so much !
Thank you so much !
Solved by Sebastian_Eiche. Go to Solution.
this is working with element contour. I made a screencast for you: https://autode.sk/2AOAK9l
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Sebastian Eiche
Thank you so much Mr. Sebastian_Eiche, you are right !
Element Contour - UCS can do that. Element Contour - Rule only use for 2 pipe connection.
