Welcome to ACC Ideas! Please note not all ideas receive a response and top voted ideas will be considered for future development. Click HERE for more information on the feedback process. Thank you for your ideas!
Autodesk Takeoff - Allow Use of Count in Quantity Formulas for Count-Based Takeoff Types
Currently, when using Count-based Takeoff Types in Autodesk Takeoff, there's no way to reference the total number of placed instances within the quantity formula. This limits real-world use cases where the count drives a physical quantity, such as:
  • Volume of concrete for column pads or piers
  • Total weight for equipment or precast units
  • Labor/machine estimates based on item quantity
Even though you can define variables like depth, width, and height, there's no ability to multiply these values by the total count to drive cumulative totals. A single instance is calculated correctly, but the summary line in the package doesn’t reflect aggregate quantity.
Introduce a built-in variable, like Count, that can be used in formulas. For example:
Count * Depth * Width * Height / 27 (to get total CY of concrete for however many Column Pads there are)
This would unlock real-world outputs without requiring post-export math or switching tools.
5 Comments
sara.hendler
@cade_long I believe this is possible.  See screenshot.
cade_long
@sara.hendler can you click the Volume additional output and show the formula?
sara.hendler
@cade_long Here you go.
cade_long
@sara.hendler Here is what I have. This all looks the same to me?
Screenshot 2025-08-07 141155.pngScreenshot 2025-08-07 141201.pngScreenshot 2025-08-07 141129.pngScreenshot 2025-08-07 141136.pngScreenshot 2025-08-07 141145.png
cade_long
I figured out the issue here. The takeoff type must have all parameters (W, H, D) defined before a takeoff is performed, otherwise you must go back to each takeoff instance in Inventory and assign the WHD there.
