Welcome to ACC Ideas! Please note not all ideas receive a response and top voted ideas will be considered for future development. Click HERE for more information on the feedback process. Thank you for your ideas!
Added feature to edit zip file name when downloading file
My customer uses the "Share - anyone with the link" function to share data with a partner. Their folder name is quite long, please see the attached
- When downloading a zip file, the zip file's name will be the folder's name with the "date + time" the file was downloaded. EX: "Folder name + date + time".zip
- After downloading, my customer cannot view the PDF file in a zip file due to a long path error when they open directly the PDF file in the zip file. The path shown on File Explore of the window will include: " zip file's name + folder's name + file's name" => long path error.
- If they extract a zip file. They can view files normally.
=> So I propose adding the ability to edit the zip file name when downloading the file.
1 Comment
mthomas99EQC
Please consider this for Sheet exports as well!
At a minimum I would like to have the option to add or remove certain metadata from the file ie. Date, Time, etc.
Thanks!
