Message 1 of 13
Transfer Projects feature now available in the new A360
- Mute
- Permalink
- Report
The Transfer Projects feature is useful if you want to consolidate projects from several hubs into a single hub or if you recently signed up for a Team Hub and you would like to transfer projects from your personal hub into the new team hub.
In the Project listing page under the context menu for each project you should see an option to Transfer the project.
Here are some rules that govern how the Transfer Projects feature works:
- Feature ‘Transfer Projects’ helps A360 Admins to transfer projects across various A360 hubs.
- Only Admins of the A360 Hubs will be able to transfer projects across hubs. In case Of A360 Free hubs, hub owner will be able to transfer projects.
- The user who is initiating the project transfer should be an Admin of the Source hub and should be a Member(Admin/Team Member) of the Destination hub
- Projects can be transferred from A360 Free to A360 Team and from A360 Team to A360 Team hubs only. Project transfer doesn't support transfer from A360 Team to A360 Free hubs.
- User should be part of multiple hubs, for the Transfer Projects option to show up. If the User owns or administers a single hub, then the option wont be available.
- Once Project Transfer is initiated and is successful, all content in the selected project will be transferred into a Secret project of the same name in the destination hub. All members of the selected project will be invited as Project Contributors, unless they are already Team members of the destination hub.
- Once Project is moved, all the project content will be deleted from the Source hub and the project will be available only in the Destination hub
- While adding project members into the destination hub, always the role of the users in the destination hub is taken into consideration.
- Currently ‘Transfer Projects’ option is disabled for C4R Enabled hubs
Rahul Bhandarkar
Sr. Product Manager - A360
rahul.bhandarkar@autodesk.com
