A360 Forum
Welcome to Autodesk’s A360 Forums. Share your knowledge, ask questions, and explore popular A360 topics.
Advance steel model retains model views
3 REPLIES 3
iwafb
330 Views, 3 Replies
Hi All,
I have uploaded a model to A360 Team and it seems to have retained the model view. That is, the model is showing clipped and I can't seem to control this or layer display within A360 so that the recipients can view the whole model.
Can this be controlled?
Thanks.
Dart
3 REPLIES 3
Bud_Schroeder_ADESK
in reply to: iwafb
Hi Dart
I don't have Advanced Steel, but I just did a quick test using AutoCAD 2018.  I created a simple 3D drawing and adding a layout to it.  Then created multiple views using the AutoCAD View command.  Note that I did need to wait for all the views to translate before I was able to view them, but I can see all the views I created. See screenshots below. Note that you may also want to do a zoom extents and save before you upload the file.
Hope this helps and have a great day.
Bud Schroeder
AutoCAD Customer Council Beta Programs
Autodesk Inc.
Join the AutoCAD Customer Council Beta Program.
iwafb
in reply to: Bud_Schroeder_ADESK
Hi Bud,
Thanks for your reply.
I assume this is an Advance Steel issue, but the A360 viewer is not showing the views like in your screen dump, so I can't control the display...
Cheers,
Dart
Bud_Schroeder_ADESK
in reply to: iwafb
Thanks Dart for the update and yes, please check with the Advanced Steel guys on this. Also what happens if you create a DWF or DWFx does that work?
Bud Schroeder
Autodesk Inc.
