3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Arnold AOV's
4 REPLIES 4
jamesw
1039 Views, 4 Replies
Arnold AOV's
I am trying to move over from Mental Ray to Arnold.
I have always used passes from my renders to composite in After Effects.
I have worked out how to extract each pass in after effects with extractor but z depth not working or material ID's
Can anyone explain how to use a z-depth with Arnold AOV's in after effects.
Also material ID's. For this I just want everything Black except the material I use for spot lights.
There is very little information with regards to Arnold for use with 3ds Max. If I cant get this to work I will use V-ray in the future as there is way more info out there.
4 REPLIES 4
Stephen.Blair
in reply to: jamesw
jamesw
in reply to: Stephen.Blair
That's the tutorial I followed but didn't work from Max to after effects. z depth just shows as white and playing with setting does nothing. There is no way to control z-depth distance from what I can see either.
Spent 1 day trying to do this. It was easy with Mental ray.
Just spent half hour playing with V-ray and got all the passes I need without problem. Not impressed with Arnold speed either compared to other two engines.
Stephen.Blair
in reply to: jamesw
The Z AOV isn't normalized. How did you normalize the values for viewing?
// Stephen Blair
// Arnold Renderer Support
ted
in reply to: jamesw
I have the same issue and haven't seen an answer. The AOV Z renders out a white image. I've tried rendering a Tiff and adjusting exposure but there is no information there. I finally downloaded the pool ball tutorial to try that and got the same blank white image out of z. Here's the tutorial if anyone can tell me how to get a workable Z depth image out of it.
https://docs.solidangle.com/display/A5AF3DSUG/Z+Depth+AOV
