10:07 AM
I have a sun positioned through a window and then a rectangle photometric at that window to diffuse light throughout the room...like a portal.
But it appears the recetangle light is blocking the sun. It is casting a shadow as if I have a plane there.
If I go to properties panel for the light I cannot uncheck "cast shadow". If I uncheck "renderable" then the light doesn't work at all.
(the above is not to be confused with the "cast shadows" settings of the light itself. I want the light to cast shadows in the scene. I just don't want the shape of the light to block other lights.)
It seems there should be a simple fix to this but I'm not finding it.
