3ds Max Programming
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max SDK, Maxscript and Python topics.
seam clear hotkey script
6 REPLIES 6
slava.lobanov.1990
521 Views, 6 Replies
Hello. Can I somehow create a script that will work through a hotkey that will remove the blue seam from the model?
Now this can be done through the clamped alt in the seam editing mode. I need this option without activating this mode.
The hotkeys have Edge Sel to Pelt Seam (Add)  this marks the seam on the desired edges. I need a reverse operation on another button.
I saw a video of a paid script and there was a button to clean the seams. How to make only this option separately without everything else?
Labels (1)
6 REPLIES 6
macroScript HideSeams
	category:"UVW Unwrap Helpers"
	toolTip:"Hide Seams"
	try ((modpanel.GetCurrentObject()).setPeltSelectedSeamsByNode #{} selection[1]) catch()
how to assign a hotkey to a macro, you probably know yourself
	local modi = undefined
	fn enabled = (iskindof (modi = modpanel.GetCurrentObject()) Unwrap_UVW)
	on isEnabled do (enabled())
	on execute do if enabled() do (modi.setPeltSelectedSeamsByNode #{} selection[1])
That's what you need. This is the only way he removes all the seams from the entire object at once. It is necessary to remove only from the selected edges.
		ss = #{}
		if keyboard.shiftPressed do
			ss = modi.getPeltSelectedSeams()
			ee = modi.getSelectedGeomEdges()
			ss -= ee
		modi.setPeltSelectedSeams ss
with SHIFT clear selected edges, without SHIFT clear all
Thank.
Technology Administrators
