Hello. Can I somehow create a script that will work through a hotkey that will remove the blue seam from the model?
Now this can be done through the clamped alt in the seam editing mode. I need this option without activating this mode.
The hotkeys have Edge Sel to Pelt Seam (Add) this marks the seam on the desired edges. I need a reverse operation on another button.
I saw a video of a paid script and there was a button to clean the seams. How to make only this option separately without everything else?
Solved by denisT.MaxDoctor. Go to Solution.
macroScript HideSeams
category:"UVW Unwrap Helpers"
toolTip:"Hide Seams"
try ((modpanel.GetCurrentObject()).setPeltSelectedSeamsByNode #{} selection[1]) catch()
how to assign a hotkey to a macro, you probably know yourself
local modi = undefined
fn enabled = (iskindof (modi = modpanel.GetCurrentObject()) Unwrap_UVW)
on isEnabled do (enabled())
on execute do if enabled() do (modi.setPeltSelectedSeamsByNode #{} selection[1])
That's what you need. This is the only way he removes all the seams from the entire object at once. It is necessary to remove only from the selected edges.
@slava.lobanov.1990 wrote:That's what you need. This is the only way he removes all the seams from the entire object at once. It is necessary to remove only from the selected edges.
ss = #{}
if keyboard.shiftPressed do
ss = modi.getPeltSelectedSeams()
ee = modi.getSelectedGeomEdges()
ss -= ee
modi.setPeltSelectedSeams ss
with SHIFT clear selected edges, without SHIFT clear all
