Announcements
Manipulated on the local axis within the controller script?
dg3duy
dg3duy
Sample scene
I wonder how it can be manipulated on the local axis within the controller script?
denisT.MaxDoctor
use the position script controller as second controller of Position List controller.
dg3duy
The result in this case is the same if I place the script in the second place in the list of controllers, I hope I understood the answer.script controllers 2.gif
denisT.MaxDoctor
Oh. I didn't read your question carefully ... so maybe this will work for you:
delete objects
target = circle name:#target radius:10 wirecolor:red isselected:on
source = point name:#source size:10 box:on axistripod:on cross:on wirecolor:green
p = source.pos.controller = position_list()
p.setname 1 "Main Pos"
c = p.available.controller = position_script()
p.setname 2 "Driven Pos"
c.addobject #rot source.rotation.controller
c.addnode #pos target
c.setexpression "[pos.pos.z, 0, 0] * rot.value"
denisT.MaxDoctor
the solution may be different. it depends on what exactly you want to do ... it is more likely that it is better to move in the parent coordinate system rather than in the local
denisT.MaxDoctor
delete objects
parent = dummy name:#parent
source = point name:#source size:10 box:on axistripod:on cross:on parent:parent wirecolor:green
c = source.pos.controller = position_script()
c.setexpression "[pos.pos.z, 0, 0]"
move parent [0,20,0]
rotate parent (eulerangles 0 0 45)
dg3duy
Very good examples, now I have to see which of the 2 I am going to use.
Excellent contribution as always! thank you very much
