3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
problem getting my scale, rotate, and move to work on 3Ds Max
7 REPLIES 7
Message 1 of 8
2938 Views, 7 Replies
 i have been trying to fix this problem for my hot keys for moving scaling and rotation tool is not working the tool shows up on the objest but wont move or scale or rotate. this is urgent and need this fixed asap!
7 REPLIES 7
Message 2 of 8
BenBisares
Can you attach an archive of your scene? (Application Menu > Save As > Archive)
I was thinking it was due to the Move/Rotate/Scale locks being enabled but you said it wasn't the case.
Could also be that Position/Rotation/Scale controllers are not set to the default.
Ben Bisares
Message 3 of 8
in reply to: BenBisares
Message 4 of 8
BenBisares
Yeah, it's what I suspected. Your object Controllers are not set to the default. Perform the following:
    -Select your object
    -Go to the Motion tab > Assign Controller >
        -Select the "XRef Transform : XRef" controller (How it ended up like that, not sure)
        -Click on the Assign Controller button
        -Choose Position/Rotation/Scale
        -At the same time check and see if it's set to that for the Default (Look at the bottom of that window). If not set Position/Rotation/Scale to the default
Tell me if that works.
Ben Bisares
Message 5 of 8
it worked. thank you so very much!
Message 6 of 8
BenBisares
No problem. Glad to be of help.
Ben Bisares
Message 7 of 8
Steve_Curley
A word of advice, when you see a warning dialog like the one you saw when making some other controller the default - read it carefully because they're there for a reason. If you're not sure, stop and check the Help to work out if you really want to do it or not.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 8 of 8
i cant working move ,scale, rotration tool
