Hi all, new to the forums and 3ds Max in general. I'm at my wits end here. This is my first time using the program so I may be doing something completely wrong but I need help! I'm trying to model a fender, and I created it by first drawing three lines, attaching them, applying the surface modifier, and then converting it to an editable polygon. This is what it looks like in my viewport.
However, when I try to render it, only the underside renders and any part of the top side that is visible is completely blank, hiding everything. Here is that same fender rendered.
It doesn't matter how the object is rotated.
It still renders ONLY the bottomside and the top is completely invisible and cloaks everything else.
I don't know enough about the program to know what to do to fix this, but it's very frustrating! I've been following a tutorial to learn how to use the program and they don't seem to run into this issue or address it. Here is what is happening in my model
What it's supposed to look like
What it renders as
Any help would be GREATLY appreciated!!!
Solved by PROH. Go to Solution.
Hi. In Max (and most other 3d programs) faces are basically only visible from the front side, and invible when seen from the back side. Which side that's front and which back are determined by the "normals" direction.
In your case your objects is backside out, so it needs to be flipped. This can be done in the modifier panel (select all polygons and press "flip") or by applying a "normal" modifier set to "flip". A third solution could be to set the render to "Force two-sided". This will force the renderer to render both sides, and therefore basically also forcing the renderer to calculate twice as much as "needed". So I would recommend only to use this as a quick fix for small models.
Hope it helps
