I use MAX2023.2 editable polygons — chamfer, crash, stuck。
Solved by DanielCantin. Go to Solution.
Thanks @951220590 for reporting the issue.
As you reported, this affect only 2023.2 and chamfer, more precisely on free/open edges, we are working on a fix, loading files that have this kind of chamfer can also cause a freeze when loading them in 2023.2. We greatly appreciate all the help we received from the community, like your description of what cause the issue, we are very sorry for the trouble it can cause.
Here a few other related forum post:
- 2023.2 Broke my scene
- Chamfering any edge on an open mesh causes 3Ds Max 2023.2 to hang up and load CPU to 100%
- URGENT - 2023.2 update cannot open scenes created previous 2023 version?
We are working on the fix and are planning to release it as soon as it is ready.
I am pleased to share that an update to 3ds Max, version 2023.2.2, is now available to download through the Autodesk Desktop App (ADA) or through the manage.autodesk.com download portal. This update resolves an issue with Chamfer operations in 3ds Max 2023.2 which resulted in the software entering an endless loop and becoming unresponsive either when loading files (locking up at 73% load) or when applying a Chamfer (through the Chamfer modifier, or Editable Poly or the Edit Poly modifier) to edges that connected to an open edge on your mesh data when using “Limit Effect”.
On behalf of the 3ds Max team I would like to thank everyone who took the time to share their scenes and report this issue to us, your help enabled us to quickly confirm and resolve the issue.
I would also like to take another opportunity to apologize for this issue. We are all as deeply disappointed as you are that this issue shipped with 2023.2, and we hope that with 2023.2.2, and future releases of 3ds Max, will resume the positive trend of releases that provided the stability, features, and functionality that assists you to create expressive content and share creative experiences in your work.
Logan Foster
Product Owner at Autodesk for 3ds Max
Hi, I still have a similar issue after the update. I have a very simple test object, started as a editable spline, added an edit Poly.
Wenn I select a horizontal edge and hit the Chamfer settings button, Max crashes 100% with an overload on the CPU.
i will attach the Max file.
- Jeroen
