Hello
I had the same problem but it was solved doing the following:
Choose your floor generator pattern - go to it's parameters (in the modify section) - "Warnings" and change "Max boards" number, increase it to a higher number of boards and that should solve the problem.
Kind Regards,
GM
Thanks a lot @Anonymous ! Its saved my time.
I wish to add hereby that : After entering some "big value" for the Maximum Boards under the Warnings dropdown... You must change the value/values that you might have reduced or increased before. Most probably changing the value of the Len/Width under the Board size dropdown. Hope it works for you too😊 Happy creativity guys!🤓
Hello, I'm having the same issue, where can I find the "Warnings" section? I don't see it in the Modify panel.
Thanks!
Hello guys i tried to fix it with the parameters as said bas once im clicking on it the error message is popping again, any other solutions? Or the plugin might be the issue?
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Good afternoon,
I have a problem with the floor generator, this error appears:
Can someone help me?
Thank you
Check if you have a flat surface first. A quick way to do it is select all the vertices and then scale it down in Z.
other Floor patterns are not showing..Please tell me what is causing this problem? pls help me kindly..
Hi, please help. I'm having the same issue as I have tried to increase the Max Board number, and it is not working, also the floor pattern doesn't show as normal, it caused my PC crushed a couple of times.
