3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Floor Generator Plugin Error Message
13 REPLIES 13
Message 1 of 14
14132 Views, 13 Replies
Dear Sir or Madam,
My name is Jason Crawford and I have recently downloaded the product 'Floor Generator' for 3DS Max 2021. Unfortunately, I have encountered numerous error messages when trying to use the product, therefore, I was wondering if you could please advise me on using this product?
After installing the plugin to my computer files, I have tried to use the plugin on several different files/shapes/editable polys within 3DS max, but unfortunately, I keep encountering the same warning message and eventually crashes 3DS Max.
The message is as follows:
"Pattern Creation Warning
More boards created than specified in max boards.
Either raise the maximum, or make the boards larger
ok to continue or cancel creating floor?"
I have also tried to modify the Floor Generator parameters and max boards warning, but the error continues to flag every time I change one parameter.
Please could you advise on how this could be resolved as I would very much appreciate any advice you may have? I am a new user to 3DS Max and am struggling to identify the problem.
Thank you in advance for any solutions you may have.
Kind Regards,
Jason
13 REPLIES 13
Message 2 of 14
I have the same problem. i could not find a solution. Did you solve the problem?
Message 3 of 14
Hello
I had the same problem but it was solved doing the following:
Choose your floor generator pattern - go to it's parameters (in the modify section) - "Warnings" and change "Max boards" number, increase it to a higher number of boards and that should solve the problem.
Kind Regards,
GM
Message 4 of 14
Thanks a lot  @Anonymous ! Its saved my time.
I wish to add hereby that : After entering some "big value" for the Maximum Boards under the Warnings dropdown... You must change the value/values that you might have reduced or increased before. Most probably changing the value of the Len/Width under the Board size dropdown.  Hope it works for you too😊 Happy creativity guys!🤓
Message 5 of 14
marina
Hello, I'm having the same issue, where can I find the "Warnings" section? I don't see it in the Modify panel.
Thanks!
Message 6 of 14
cynthia_slim
Hello guys i tried to fix it with the parameters as said bas once im clicking on it the error message is popping again, any other solutions? Or the plugin might be the issue?
Message 7 of 14
rendermaster
in reply to: marina
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Message 8 of 14
amandaoliveira_10_
Good afternoon,
I have a problem with the floor generator, this error appears:
Can someone help me?
Thank you
Message 9 of 14
Check if you have a flat surface first. A quick way to do it is select all the vertices and then scale it down in Z.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Message 10 of 14
realdesigncourses
  1. Turned off the floor generator modifier.
  2. Centered the pivot within the shape.
  3. Executed 'Reset XForm' in the utilities tab.
  4. Ensured it's positioned below the floor generator in the modifier stack.
  5. Turned the floor generator back on.
Message 11 of 14
roysourav746
other Floor patterns are not showing..Please tell me what is causing this problem? pls help me kindly..
Message 12 of 14
rendermaster
in reply to: roysourav746
maybe you are using the free version
Message 13 of 14
Hi, I'm having the same issue, and it caused my PC crushed
Message 14 of 14
joyce-tian-white
Hi, please help. I'm having the same issue as I have tried to increase the Max Board number, and it is not working, also the floor pattern doesn't show as normal, it caused my PC crushed a couple of times.
