3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Extrude Corners
13 REPLIES 13
Message 1 of 14
1695 Views, 13 Replies
Extrude Corners
I am a new 3ds Max user.
I come from Modo and other 3D Software.
How can I perfectly extrude the corner of a rectangle? (This is only an example, but I think that the tecnique to do that can be applied to other meshes). In Modo I can use the bevel tool to achieve that.
Do you have a solution to do it with a tool? I hate moving vertices or edges by freehand.
Thank you for your help.
13 REPLIES 13
Message 2 of 14
don_3259
hi please show me what final result you want to get i not think we can extrude edge in 3ds max direct way...please show me result you want to get....thanks
Autodesk Student Amassdor
Guest & Visiting Lecturer
Ali Sajjad
Message 3 of 14
in reply to: don_3259
Hi. Thank you for answering me.
Message 4 of 14
don_3259
select that up face and use inset option to do that if you not understand share file here i do that for you ....thanks
Ali Sajjad
Message 5 of 14
But I do not want reverse the process. Maybe one day I will need to extrude the face and have that shape. In my work this features is very important.
Message 6 of 14
don_3259
yes inset command is solution for getting that result you can use it to get that result and get same thing and extrude face you want...thanks
Ali Sajjad
Message 7 of 14
Thank you for your help. I really need to understand how to use the inset tool to extrude faces.
Could you send me a video or a link?
Message 8 of 14
don_3259
hi you can check on following link that video is showing how inset command works accept solution and give kudo...thanks
Ali Sajjad
Message 9 of 14
I am sorry but I don't think that you ubderstand what I have to do. It doesn't work. I need to extrude the corner ina  precise way.
Message 10 of 14
don_3259
we can extrude the face in any side using spline as guide also you know that ?
Ali Sajjad
Message 11 of 14
No, I don't know that. Could you please show me how?
Message 12 of 14
don_3259
please check this video...thanks
Ali Sajjad
Message 13 of 14
kgokhangurbuz
Hi;
You can achieve this by Extrude command, with Local Normal Option (image 01):
But you will see that your object has been deformed, so you will need to view align those faces seperately with the tools under Edit poly > Edit Geometry section (image 02)
These sub selection align tools work on local coordinates, so dont worry if your object is rotated after it's created.
Regards;
Message 14 of 14
RGhost77
in reply to: kgokhangurbuz
