Extrude Corners
Extrude Corners
I am a new 3ds Max user.
I come from Modo and other 3D Software.
How can I perfectly extrude the corner of a rectangle? (This is only an example, but I think that the tecnique to do that can be applied to other meshes). In Modo I can use the bevel tool to achieve that.
Do you have a solution to do it with a tool? I hate moving vertices or edges by freehand.
Thank you for your help.
Replies (13)
don_3259
hi please show me what final result you want to get i not think we can extrude edge in 3ds max direct way...please show me result you want to get....thanks
Autodesk Student Amassdor
Guest & Visiting Lecturer
Ali Sajjad
Hi. Thank you for answering me.
don_3259
select that up face and use inset option to do that if you not understand share file here i do that for you ....thanks
Ali Sajjad
But I do not want reverse the process. Maybe one day I will need to extrude the face and have that shape. In my work this features is very important.
don_3259
yes inset command is solution for getting that result you can use it to get that result and get same thing and extrude face you want...thanks
Ali Sajjad
Thank you for your help. I really need to understand how to use the inset tool to extrude faces.
Could you send me a video or a link?
don_3259
hi you can check on following link that video is showing how inset command works accept solution and give kudo...thanks
Ali Sajjad
I am sorry but I don't think that you ubderstand what I have to do. It doesn't work. I need to extrude the corner ina  precise way.
don_3259
we can extrude the face in any side using spline as guide also you know that ?
Ali Sajjad
No, I don't know that. Could you please show me how?
don_3259
please check this video...thanks
Ali Sajjad
kgokhangurbuz
Hi;
You can achieve this by Extrude command, with Local Normal Option (image 01):
But you will see that your object has been deformed, so you will need to view align those faces seperately with the tools under Edit poly > Edit Geometry section (image 02)
These sub selection align tools work on local coordinates, so dont worry if your object is rotated after it's created.
Regards;
