3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Viewport Canvas 2016 truble: applying dark color to texture
3 REPLIES 3
niklit.y
992 Views, 3 Replies
And  after painting texture save with this dark color
Please help, why i have this?
3 REPLIES 3
darawork
in reply to: niklit.y
Hi, it looks like you are using two different alpha levels. Check to see if your bitmap is the same as the scene alpha... it should be 2.2 for most regular uses.
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
lightcube
Viewport Canvas is something I use a lot. But it does suffer from being unintelligent about image gamma. As soon as you load it up, it is prone to immediately change the gamma of your image in the viewport.
Vote for it to be fixed:
http://3dsmaxfeedback.autodesk.com/forums/76763-small-feature-requests/suggestions/4034429-viewport-...
Shawn Olson
Developer of Wall Worm
3ds Max plugins and Scripts
3ds Max 4/Gmax - 3ds Max 2020
Mudbox 2009-2019
Windows 10 x64
i7 8700K
64GB RAM
Geforce 1080ti
darawork
in reply to: darawork
Oops, I obviously meant Gamma. Doh!
Sounds like a nasty 'feature' alright.
Darawork
AutoDesk User
