And after painting texture save with this dark color
Please help, why i have this?
Hi, it looks like you are using two different alpha levels. Check to see if your bitmap is the same as the scene alpha... it should be 2.2 for most regular uses.
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
Viewport Canvas is something I use a lot. But it does suffer from being unintelligent about image gamma. As soon as you load it up, it is prone to immediately change the gamma of your image in the viewport.
Vote for it to be fixed:
Oops, I obviously meant Gamma. Doh!
Sounds like a nasty 'feature' alright.
Darawork
AutoDesk User
