Objects not visible in layer manager in 3DS Max 2019.1.1
Message 1 of 8
ARGH! This bug still exists in latest Max 2019.1.1
My incremental scene save save has no layers at all.  If I right click an object and view object properties and can see there is a named layer assigned to it but all I have in the layers panel is "0 (default)" with nothing in it.  This happened just after opening my scene where an XRef was missing which I fixed, if that has any bearing to it.
The accepted answer is not an answer for me, I have detailed layers within layers in this scene so DO NOT want to shove everything into one layer.  All I can do is go back to a previous save and lose my work.
Using dual monitors too, prior to this save was using one monitor.
Your post has been made into its own thread by @hagen.deloss: the original thread can be found here.
Replies (7)
Message 2 of 8
hagen.deloss
Hello @Anonymous
Thanks fro bringing your question to the forums! This issue sounds super frustrating, I'm hoping that we can figure this out together 😄
Would you be able to send me a test file so I can see exactly what the issue is you are encountering? You can either attach it to your next post in a zip file, or send a file sharing link in a private message to me!
  • Have you tried reproducing this issue when working on one monitor?
  • What happens if you group the objects, or attach the objects? Does anything change in the scene explorer?
  • If you can't attache an example file, screenshots of your scene explorer and object properties would be super helpful
Talk to you soon!
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 3 of 8
hagen.deloss
Hi @Anonymous
I wanted to check back and see if a post helped you with your problem. It would be super helpful if you could add a post with how you decide to proceed, and your results. That way other Community members can benefit from your process 😄
Please select the Accept as Solution button if a post solves your issue or answers your question.
Hagen Deloss
Message 4 of 8
Hi
I could not find a feasible solution so reverted to an older save and overwrote from there onward so I do not have the file.  If it happens again I will be back.
Message 5 of 8
hagen.deloss
Hi @Anonymous
Thanks for the update! I hope it doesn't happen again, and best of luck on the project 😄
Hagen Deloss
Message 6 of 8
here is another way automatic retrieve all your layers and objects
you can download my script from here:
Message 7 of 8
digitalprogression
Tried the script posted elsewhere but no joy.
The script purchased from above worked perfectly
Message 8 of 8
jibijib
I had this problem after working on a mesh from 2004/2005 !!
I could not get the object visible in the layer or scene explorer - apart from creating an object from scratch, and attaching the object to this.
A quick and easy method is to just highlight the object and go to Tools > Snapshot and delete the old one.
