Bindings not working
Hello guys!
Something happened in the previous days with the program and no button combinations (Ctrl + Z, Delete and others) work. PLEASE HELP ME:(
miledrizk
Maybe something messed up your User Settings, like a newly installed plugin or something,
You can try resetting them like this:
1- Close 3DS Max
2- Go to: C:\Users\yourusername\AppData\Local\Autodesk\3dsMax\20xx - xxbit
3- Rename the folder called ENU to something else like ENU.old
4- Restart Max
Note: AppData is a hidden folder, so you need to enable show hidden files and
Folders from the Control Panel
[email protected]
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
brentscannell
Hi @Anonymous
May I ask what version of 3ds Max you are using?
hagen.deloss
Hi @Anonymous
I wanted to check back and see if @brentscannell or @miledrizk's posts helped you with your problem? It would be super helpful if you could add a post with how you decide to proceed, and your results. That way other Community members can benefit from your process 😄
Please select the Accept as Solution button if a post solves your issue or answers your question.
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
