Installation & Licensing
3ds Max will not install (Monitor.exe)
71 REPLIES 71
Message 1 of 72
124684 Views, 71 Replies
I have no idea what this monitor.exe is, but I cannot find it in the task manager to close it so I can install this program. Please help, my attempts to google solutions have failed.
71 REPLIES 71
Message 2 of 72
philip.s
Welcome to the community Kaitlyn!
Perhaps this thread will help? Specifically:
Start > Run
Taskkill /f /im monitor.exe
Please accept as a solution if this fully resolves the issue, or reply with additional specifics if the problem persists.
Message 3 of 72
thank you very much it helped
Message 4 of 72
in reply to: philip.s
I've tried doing that but the monitor.exe keeps popping up. Is it because I have windows 8 or am I just doing something wrong?
Message 5 of 72
roelv30
if you have windows 8 or 8.1 then right click on your windows 8.1 button (in the left corner of your screen) then open command promp(admin)
and paste: Taskkill /f /im monitor.exe then press enter
then if you press the 'Ok' button in the installation it will work
Message 6 of 72
when i put in the comand promp it says its denied what do i do then
Message 7 of 72
jotagore
open the command prompt as admin 😉
Message 8 of 72
Message 9 of 72
in reply to: jotagore
I love you. You just saved my day. Its working perfectly and now I can install it too. (windows 8, 64x)
Message 10 of 72
I still can't install it. This message appears as I enter "Taskkill/f /im monitor.exe". The message is "Error: The process "Monitor.exe" with PID 4904 could not be terminated. Reason: Access is denied" Please help. Thank you in advance.
Message 11 of 72
run CMD as admin, it worked for me and I used to have the same problem than you.
Message 12 of 72
roelv30
sorry for answering so late but maybe it helps you afterwards, Have you tried to start windows in safe mode? or have you tried running the command prompt in admin mode
Message 13 of 72
not working at all for me and ive run task kill like 8 times and neither 2014 or 2015 will work or install on my computer n i need it for class
Message 14 of 72
Thanks it really helped!
Message 15 of 72
Hi Philip
I had the Autodesk 3ds Max student version for 2014 installed and I would like to uninstall that and install the Max 2016 but there is this popup that blocks the uninstallation about some monitor.exe is open. I called out my Task Manager and it does not show any open app - what is this monitor.exe that is blocking?
So I followed your Taskkill /f /im monitor.exe and click Ok then the uninstallation does not ahev a popup block BUT now the uninstallation process is still not moving. Pls help as I need to get it uninstall and get teh 2016, please.
Thank U.
zedar
Message 16 of 72
3dmax monitör.exe hatası yüzünden yüklenmiyor hep hata veriyor yardım istiyorum....
Message 17 of 72
2khanke
You can open Task Manger; click the 'Processes' tab & scroll down to 'monitor.exe' - select and end process. The install will resume.
Message 18 of 72
Thank you for the solution, this was driving me nuts!
Message 19 of 72
If I close the monitor.exe my laptop crashes and gives me a blue screen saying Kmode exemption not handled. pls help
Message 20 of 72
Administrator Productivity
