Maybe a good idea for you to check Autodesk's localized websites then, since
some do offer
foreign language discussion groups.
HTH
VJoseph
"torreon" wrote in message
news:423a8774$1_1@newsprd01...
> Hi:
> Sorry but i don't speak english (a little).
> thank you
> "Scott Sheppard - Autodesk" escribió en el
> mensaje news:4239b0f6_3@newsprd01...
>> If I understand your question correctly.
>> 1. You can use Autodesk Map 3D to generate DWF files from your DWG files.
>> These DWF files can be viewed with Autodesk DWF Viewer or Autodesk DWF
>> Composer. The hyperlinks should transfer from the DWG to the DWF, so you
>> should be able to navigate the hyperlinks in the resulting DWF files
>> using the Autodesk DWF Viewer or Autodesk DWF Composer. DWF Composer will
>> also allow you to markup and measure those DWF files.
>> 2. DWF Composer comes with a DWG Viewer. If you want to view DWGs created
>> by AutoCAD Map 3D you will want to download and install the object
>> enabler. The DWG Viewer should allow you to navigate the hyperlinks in
>> the DWGs.
>> Drawings are saved in their native format and transferred to the
>> recipient who should install the Autodesk Map 3D 2005 Object Enabler to
>> enable Autodesk Map 3D 2005 objects.
>> news:42395bb7$1_3@newsprd01...
>>> Hi:
>>> I have read the DWF Composer FAQ, but I don´t know if it's posible to
>>> consult Autodesk Map's data in DWF composer (links) and generate tematic
>>> maps.
>>> Where I can get this information??
>>> thanks
