I need to rename some nodes in a classification tree but I keep on getting the exception.message "eInvalidInput" from the exception.source Acdbmgd.
Any suggestions?
Here is the code:
<Autodesk.AutoCAD.Runtime.
CommandMethod("RenameClassificationTreeNode")> _
PublicSub RenameClassificationTreeNode()
Dim ed AsEditor = Application.DocumentManager.MdiActiveDocument.Editor()
Dim db AsDatabase = HostApplicationServices.WorkingDatabase
Dim tr AsTransaction = db.TransactionManager.StartTransaction
Try
Dim dict AsDictionaryClassificationDefinition = NewDictionaryClassificationDefinition(db)
Dim ids AsObjectIdCollection = dict.Records
Dim id AsObjectId
ForEach id In ids
Dim obj AsObject = tr.GetObject(id, OpenMode.ForRead, False, False)
Dim classCollDef AsClassificationDefinition = obj
If classCollDef.Name = ("AAU_SfBClassification") Then
Dim classTree AsClassificationTree = classCollDef.ClassificationTree()
RenameTreeNode(tr, classTree)
EndIf
Next
Catch ex AsApplicationException
tr.Abort()
Finally
tr.Dispose()
EndTry
EndSub
Private Sub RenameTreeNode(ByRef tr AsTransaction, ByRef node AsClassificationTree)
If node IsNothingThenExit Sub
'Here is the task: Remove paranthesis if present
IfNot (node.Id.IsNull) Then
Dim Clsfc AsClassification = CType(tr.GetObject(node.Id, OpenMode.ForRead), Classification)
Dim OldName AsString = Clsfc.Name
If OldName.Contains("(") AndAlso OldName.Contains(")") Then
Dim Newname AsString = Replace(OldName, "(", "")
Newname = Replace(Newname,
Try
node.Rename(Clsfc.ObjectId, Newname)
' THIS FAILS!!!
Catch ex AsException
MsgBox(ex.Message)
EndTry
EndIf
EndIf
If node.Children.Count > 0 Then
ForEach ChildTree In node.Children
RenameTreeNode(tr, ChildTree)
Next
EndIf
EndSub
Hi Jan,
I did not try your code, but looks like your code is written in read only mode. If you want to modify database objects, you will need to open for write and commit transaction.
Here is a sample code that goes through the nodes and add " API" to the name of each node. I hope this helps.
'' Rename classification definition tree names
<CommandMethod("ACANet", "RenameClassificationDefTree", CommandFlags.Modal)> _
PublicSub RenameClassificationDefTreeNames()
'' Some basic things here
Dim ed AsEditor =
'' Start a Transaction
Try
'' get the dictionary for the classification definition,
'' and list of records in it
Dim id AsObjectId
'' loop through each classification def
ForEach id In ids
Dim obj AsObject = tr.GetObject(id, OpenMode.ForWrite, False, False)
'' print out the name of the classification.
ed.WriteMessage(classCollDef.Name + vbCrLf)
'' Get the tree and print it out
RenameClassificationTree(tr, classTree, "")
tr.Commit()
'End If
Next
tr.Abort()
System.Windows.Forms.MessageBox.Show(ex.Message)
Finally
tr.Dispose()
EndTry
EndSub
'' Given a top most node of a tree, traverse the tree
PublicSub RenameClassificationTree(
ByRef node AsClassificationTree,
ByVal sIndent AsString)
Return
EndIf
'' let's get the name of the top most node.
Dim classi AsClassification =
CType(tr.GetObject(node.Id, OpenMode.ForWrite), Classification)
node.Rename(node.Id, classi.Name + " API")
Dim s AsString = sIndent + classi.Name +
"(" + node.Id.Handle.ToString + ")" + vbCrLf
ed.WriteMessage(s)
EndIf
'' visit childen.
'' this is a intemidiate node, go through each branch.
Dim child AsClassificationTree
sIndent = sIndent + " "
ForEach child In node.Children
RenameClassificationTree(tr, child, sIndent)
Next
EndIf
EndSub
Hi Mikako
Thanks a lot for your help. I tried it out and made some minor adjustments. Then it worked out fine 🙂
Here's the final code:
Try
Dim id AsObjectId
ForEach id In ids
Dim obj AsObject
obj = tr.GetObject(id,
Next
tr.Commit()
tr.Abort()
MsgBox(ex.Message)
Finally
tr.Dispose()
EndTry
EndSub
PublicSub RenameClassificationTree(ByRef tr AsTransaction, ByRef node AsClassificationTree, ByVal sIndent AsString)
Return
EndIf
Dim classi AsClassification = CType(tr.GetObject(node.Id, OpenMode.ForWrite), Classification)
If classi.Name.StartsWith("(") AndAlso classi.Name.Substring(3, 1) = ")" Then
Dim Newname AsString = classi.Name.Substring(1)
SelectCase Newname.Length
Case 3
Newname = Newname.Substring(0, 2)
Case 4
Newname = Newname.Substring(0, 2) &
"." & Newname.Substring(3)
EndSelect
node.Rename(node.Id, Newname)
Dim s AsString = sIndent + classi.Name + "(" + node.Id.Handle.ToString + ")" + vbCrLf
ed.WriteMessage(s)
EndIf
EndIf
'' visit childen.
sIndent = sIndent +
Next
EndIf
EndSub
End
Class
