AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
How to make the rename-method of the Classificationtree work?
2 REPLIES 2
709 Views, 2 Replies
I need to rename some nodes in a classification tree but I keep on getting the exception.message "eInvalidInput" from the exception.source Acdbmgd.
Any suggestions?
Here is the code:
<Autodesk.AutoCAD.Runtime.
CommandMethod("RenameClassificationTreeNode")> _
PublicSub RenameClassificationTreeNode()
Dim ed AsEditor = Application.DocumentManager.MdiActiveDocument.Editor()
Dim db AsDatabase = HostApplicationServices.WorkingDatabase
Dim tr AsTransaction = db.TransactionManager.StartTransaction
Try
Dim dict AsDictionaryClassificationDefinition = NewDictionaryClassificationDefinition(db)
Dim ids AsObjectIdCollection = dict.Records
Dim id AsObjectId
ForEach id In ids
Dim obj AsObject = tr.GetObject(id, OpenMode.ForRead, False, False)
Dim classCollDef AsClassificationDefinition = obj
If classCollDef.Name = ("AAU_SfBClassification") Then
Dim classTree AsClassificationTree = classCollDef.ClassificationTree()
                    RenameTreeNode(tr, classTree)
EndIf
Next
Catch ex AsApplicationException
            tr.Abort()
Finally
            tr.Dispose()
EndTry
EndSub
Private Sub RenameTreeNode(ByRef tr AsTransaction, ByRef node AsClassificationTree)
If node IsNothingThenExit Sub
'Here is the task: Remove paranthesis if present
IfNot (node.Id.IsNull) Then
Dim Clsfc AsClassification = CType(tr.GetObject(node.Id, OpenMode.ForRead), Classification)
Dim OldName AsString = Clsfc.Name
If OldName.Contains("(") AndAlso OldName.Contains(")") Then
Dim Newname AsString = Replace(OldName, "(", "")
                Newname = Replace(Newname,
Try
                    node.Rename(Clsfc.ObjectId, Newname)
' THIS FAILS!!!
Catch ex AsException
                    MsgBox(ex.Message)
EndTry
EndIf
EndIf
If node.Children.Count > 0 Then
ForEach ChildTree In node.Children
                RenameTreeNode(tr, ChildTree)
Next
EndIf
EndSub
2 REPLIES 2
mikako_harada
Hi Jan,
I did not try your code, but looks like your code is written in read only mode.  If you want to modify database objects, you will need to open for write and commit transaction.
Here is a sample code that goes through the nodes and add " API" to the name of each node.  I hope this helps.
''  Rename classification definition tree names
  <CommandMethod("ACANet", "RenameClassificationDefTree", CommandFlags.Modal)> _
  PublicSub RenameClassificationDefTreeNames()
    ''  Some basic things here
    Dim ed AsEditor =
    ''  Start a Transaction
    Try
      '' get the dictionary for the classification definition,
      '' and list of records in it
      Dim id AsObjectId
      ''  loop through each classification def
      ForEach id In ids
        Dim obj AsObject = tr.GetObject(id, OpenMode.ForWrite, False, False)
        ''  print out the name of the classification.
        ed.WriteMessage(classCollDef.Name + vbCrLf)
        ''  Get the tree and print it out
        RenameClassificationTree(tr, classTree, "")
        tr.Commit()
        'End If
      Next
      tr.Abort()
      System.Windows.Forms.MessageBox.Show(ex.Message)
    Finally
      tr.Dispose()
    EndTry
  EndSub
  ''  Given a top most node of a tree, traverse the tree
  PublicSub RenameClassificationTree(
                                   ByRef node AsClassificationTree,
                                   ByVal sIndent AsString)
      Return
    EndIf
    '' let's get the name of the top most node.
      Dim classi AsClassification =
        CType(tr.GetObject(node.Id, OpenMode.ForWrite), Classification)
      node.Rename(node.Id, classi.Name + " API")
      Dim s AsString = sIndent + classi.Name +
        "(" + node.Id.Handle.ToString + ")" + vbCrLf
      ed.WriteMessage(s)
    EndIf
    '' visit childen.
      '' this is a intemidiate node, go through each branch.
      Dim child AsClassificationTree
      sIndent = sIndent + "  "
      ForEach child In node.Children
        RenameClassificationTree(tr, child, sIndent)
      Next
    EndIf
  EndSub
Mikako Harada
Developer Technical Services
Hi Mikako
Thanks a lot for your help. I tried it out and made some minor adjustments. Then it worked out fine 🙂
Here's the final code:
Try
Dim id AsObjectId
ForEach id In ids
Dim obj AsObject
                obj = tr.GetObject(id,
Next
            tr.Commit()
            tr.Abort()
            MsgBox(ex.Message)
Finally
            tr.Dispose()
EndTry
EndSub
PublicSub RenameClassificationTree(ByRef tr AsTransaction, ByRef node AsClassificationTree, ByVal sIndent AsString)
Return
EndIf
Dim classi AsClassification = CType(tr.GetObject(node.Id, OpenMode.ForWrite), Classification)
If classi.Name.StartsWith("(") AndAlso classi.Name.Substring(3, 1) = ")" Then
Dim Newname AsString = classi.Name.Substring(1)
SelectCase Newname.Length
Case 3
                        Newname = Newname.Substring(0, 2)
Case 4
Newname = Newname.Substring(0, 2) &
"." & Newname.Substring(3)
EndSelect
                node.Rename(node.Id, Newname)
Dim s AsString = sIndent + classi.Name + "(" + node.Id.Handle.ToString + ")" + vbCrLf
                ed.WriteMessage(s)
EndIf
EndIf
'' visit childen.
            sIndent = sIndent +
Next
EndIf
EndSub
End
Class
”Boost
