terminal transform matrix error
適用対象外
596件の閲覧回数
1件の返信
メッセージ1/2
適用対象外
i was wondering if any can help with with this issue,,this fault is showing up in the terminal
vrNodePtr::setTransformMatrix : Node Pointer ==NullFC!
note: i running the tracker script also, but removing it doesn't fix this issue
the VR still work well, no usage issue,, maybe a bit of lag,,
but is error floods the terminal
0 件のいいね
597件の閲覧回数
1件の返信
返信 (1)
メッセージ2/2
marcus_fritzen
this means that the vrNodePtr on which setTransformMatrix is called is not valid. Please check your script for the setTransformMatrix call and validate the associated vrNodePtr. Here is an example which shows a possible cause for the issue:
node = findNode("Foo") // there is no node with name "Foo" in our scene graph but we try to find it anyways
node.setTransformMatrix(...) -> will cause the error.
Cheers,
Marcus
Marcus Fritzen
Principal Engineer
0 件のいいね
