transform matrix issue
i was wondering if any can help with with this issue,,this fault is showing up in the terminal
vrNodePtr::setTransformMatrix : Node Pointer ==NullFC!
note: i running the tracker script also, but removing it doesn't fix this issue
the VR still work well, no usage issue,, maybe a bit of lag,,
but is error floods the terminal
michael_nikelsky
at some point in the script you are trying to set a transform matrix for a node that does not exist. You need to make sure that the nodes you are working on do exist in the scenegraph.
Kind regards
Michael
Michael Nikelsky
Sr. Principal Engineer
