zero length line
zero length line
Ranjit_Singh
Advisor Advisor
zero length line
Ranjit_Singh
Trying to do something very basic through command prompt.
Command: (setq a (getpoint))
(6.30224e+006 2.19639e+006 0.0)
Command: (setq b (polar a (/ pi 8) 0.001))
Command: (mapcar 'rtos a)
("6302237.91541349" "2196394.40151239" "0.00000000")
Command: (mapcar 'rtos b)
("6302237.91633737" "2196394.40189507" "0.00000000")
Command: LINE
Specify first point: !a
Specify next point or [Undo]: !b
Zero length line created at (6302237.91541349, 2196394.40151239, 0.00000000)
Why is it not giving me a really small line of length 0.001.... something. I used rtos to verify that the 2 points a and b do have different co-ordinates, and they do. Then why zero line length? Thanks for all your help.
hmsilva
Use "_NON" before enter !b...
Hope this helps,
Henrique
3wood
Did you turned off object snap?
