Table edit lisp
Table edit lisp
Table edit lisp
Hi guys,
I have an existing table and text objects. Does anyone know a lisp that helps you write the text in the table?Each cell different text. Doesn't have to be in the existing table actually.
leothebuilder
The question is a little vague.
If you want different text in each cell, just enter the text in the cell. No need for a lisp to do that.
it does not matter if there is or isn't text in the cell. i need a fast routine that will put/replace text in a table. i don't want to do it manually because there is too much text and it is time consuming. thank you
leothebuilder
The question is still vague.
Is the text you want to replace allways the same or is it variable each time?
If it is always the same, it makes it a lot easier obviously.
Attaching a sample of what you want to achieve would be helpful
You may get more help by posting this in the customization forum:
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/130
pendean
Community Legend
Community Legend
Show us what you mean: screenshots is a good place to start.
I have one table format, there is number of rows and columns in Auto CAD, and i have different different values for update to in table for different locations, i want add values in each table, but it will take to much time for that, Can i use any lisp for that?
Ganesh satre
AutoCAD technician - Transportation
Pune, India
+91 7709125253
