Optimization
Optimization
zph
Message 1 of 19
Optimization
zph
Good day all!
I've been using this code below for a while now and it works:
(defun c:SHNO ( / allLayoutsList allLayoutsListLength NewSheetNo titlePage nextPages)
(setvar "cmdecho" 0)
;***************** Define block name variables *****************;
(setq titlePage "_SP_TITLE_PAGE_08SEP15")   ; title page block name
(setq nextPages "_SP-Border2-F28X40_08SEP2015")   ; subsequent pages block name
(setq allLayoutsList (LAYOUTLIST))    ; gets list of all layout names
(setq allLayoutsListLength (vl-list-length allLayoutsList)) ; gets number of layouts
(setq NewSheetNo "")
;;;;;;;;;;----[un]comment to switch sheet and number formats----;
;(letterSingleX)      ;
;(letterAllXofX)      ;
;(fullAllXofX)       ;
(fullSingleX)       ;
(command "LAYOUT" "set" (strcat "Layout 1"))   ; sets "Layout 1" current
(setvar "cmdecho" 1)
(princ)
) ;SHNO
(defun fullSingleX ( / counter NewSheetNo ssTTLpageBLKsht ssTTLBLKsht)
(setq counter 1)
(while (<= counter allLayoutsListLength)
(command "LAYOUT" "set" (strcat "Layout " (itoa counter))) ; sets next paper space sheet current
 (cond
  ((= counter 1)
   (progn
   (setq NewSheetNo (strcat "" (itoa counter) " OF " (itoa allLayoutsListLength) ""))
   (setq ssTTLpageBLKsht
    (ssget "_X" (list '(0 . "INSERT")
           (cons 2 titlePage)
           '(66 . 1))))
   (setq i1 (sslength ssTTLpageBLKsht))
   (setq obj (vlax-ename->vla-object (ssname ssTTLpageBLKsht (setq i1 (1- i1)))) attlst (vlax-invoke obj 'GetAttributes))
   (foreach att attlst (if (= (vla-get-TagString att) "SHEET")(vla-put-TextString att NewSheetNo))))) ;progn ;=1
  ((and (> counter 1)(< counter allLayoutsListLength))
   (progn     ;- Pages in between first and last sheet numbers
   (setq NewSheetNo (strcat "" (itoa counter) ""))
   (setq ssTTLBLKsht
    (ssget "_X" (list (cons 0 "INSERT")
         (cons 2 nextPages)
         (cons 66 1)
         (cons 410 (getvar "ctab")))))
   (setq i2 (sslength ssTTLBLKsht))
   (setq obj (vlax-ename->vla-object (ssname ssTTLBLKsht (setq i2 (1- i2)))) attlst (vlax-invoke obj 'GetAttributes))
   (foreach att attlst (if (= (vla-get-TagString att) "SHEET")(vla-put-TextString att NewSheetNo))))) ;progn ;1< <MAX
  ((= counter allLayoutsListLength)
   (progn     ;- Last page sheet numbers
   (setq ssTTLBLKsht
         (cons 2 nextPages)
         (cons 66 1)
   (setq i3 (sslength ssTTLBLKsht))
   (setq obj (vlax-ename->vla-object (ssname ssTTLBLKsht (setq i3 (1- i3)))) attlst (vlax-invoke obj 'GetAttributes))
   (foreach att attlst (if (= (vla-get-TagString att) "SHEET")(vla-put-TextString att NewSheetNo))))) ;progn ;=MAX
 ) ;cond
(setq counter (+ counter 1))
) ;while
(princ)
) ;fullSingleX
This routine works as intended.  However, if there are any more than 40 or so sheets in my drawing file, the routine moves like a slug.  I just ran this on a drawing that has 60+ sheets and it took longer than 2 minutes.
Do you guys have any ideas how I could restructure/optimize the code so it runs faster?
Thanks!
~Z
Replies (18)
Message 2 of 19
hmsilva
Hi zph,
without set each layout current...
Untested...
(vl-load-com)
(defun c:demo (/ a adoc blks layt layts tot)
   (or adoc (setq adoc (vla-get-activedocument (vlax-get-acad-object))))
   (setq layts (vla-get-layouts adoc)
         tot   (itoa (1- (vla-get-count layts)))
   (vlax-for layt layts
      (if (not (= (vla-get-name layt) "Model"))
         (progn
            (setq blks (vla-get-block layt))
            (vlax-for blk blks
               (if (and (= (vla-get-objectname blk) "AcDbBlockReference")
                        (wcmatch (vla-get-effectivename blk) "_SP_TITLE_PAGE_08SEP15,_SP-Border2-F28X40_08SEP2015")
                        (vlax-write-enabled-p blk)
                  (mapcar '(lambda (a)
                              (if (= (vla-get-TagString a) "SHEET")
                                 (vla-put-TextString a (strcat (itoa (vla-get-taborder layt)) " OF " tot))
                          (vlax-invoke blk "GetAttributes")
   (princ)
Hope this helps,
Henrique
Message 3 of 19
marko_ribar
Yes without setting LAYOUT to active...
Modify your subfunction as follows :
Try to remove this line :
IMHO I think this is unneccessary and maybe exactly the thing that's eating time
Try to change every accurance of (ssget "_X" ... ) to (ssget "_A" ... )
Replace this line :
(foreach att attlst
With this line :
(vl-some '(lambda ( x )
  (if (= (vla-get-tagstring x) "SHEET")
    (vla-put-textstring x NewSheetNo)
    (setq x nil)
  )) attlst
);;; watch ab parenthesis you have closing progn here in your subfunction
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 4 of 19
marko_ribar
Sorry, my mistake...
This is correct :
    (progn
      (setq x nil)
    x
  )) attlst
Message 5 of 19
devitg
Hi Marko Ribar .
It is the first time I see
As I test it, it do a ALL for the SSGET , what is the difference with "_X" ??
The vlide help  do not show that option
Thank in advance
Message 6 of 19
hmsilva
@devitg wrote:
Hi Marko Ribar .
Thank in advance
Hi Gabriel,
the A mode is undocumented, is similat to X mode, and we use it to reject objects on frozen layers...
Lee Mac's ssget
Henrique
Message 7 of 19
zph
Thanks for the response, Marko.
The routine doesn't work with this though. Here is the ACAD response:
; error: bad argument type: lselsetp nil
-------------------  Here is the code modified:
(setq counter 1)
;(command "LAYOUT" "set" (strcat "Layout " (itoa counter))) ; sets next paper space sheet current
 (cond
  ((= counter 1)
   (progn
    (ssget "_A" (list '(0 . "INSERT")
           (cons 2 titlePage)
           '(66 . 1))))
    (foreach att attlst
        (progn
        (setq x nil)
        ) ;progn
       x
       ) ;if
      ) ;lambda
     attlst
     ) ;vl-some
    ) ;foreach
   ) ;progn
  )  ;counter=1
   (setq ssTTLBLKsht
    (ssget "_A" (list (cons 0 "INSERT")
         (cons 2 nextPages)
         (cons 66 1)
    (foreach att attlst
        (progn
        (setq x nil)
        ) ;progn
       x
       ) ;if
      ) ;lambda
     attlst
     ) ;vl-some
    ) ;foreach
   ) ;progn
  ) ;1<counter<MAX
   (setq ssTTLBLKsht
         (cons 2 nextPages)
         (cons 66 1)
    (foreach att attlst
        (progn
        (setq x nil)
        ) ;progn
       x
       ) ;if
      ) ;lambda
     attlst
     ) ;vl-some
    ) ;foreach
   ) ;progn
  ) ;counter=MAX
 ) ;cond
) ;while
(princ)
) ;fullSingleX
Message 8 of 19
zph
Thank you for your response, Henrique.
However, the routine doesn't 'seem' to do anything after I ran it.
The routine finishes, but none of my sheet numbers change.
Message 9 of 19
hmsilva
You're welcome, zph!
Could you please attach a sample dwg?
Henrique
Message 10 of 19
devitg
Thanks HMSILVA
Message 11 of 19
zph
Sure, here you go.
Message 12 of 19
hmsilva
It should work as expected...
Try the attached one...
Hope this helps,
Henrique
Message 13 of 19
zph
Well, it worked this time.
Would it be possible for you to make one alteration?
The 1st sheet and last sheet need to be X OF X and the sheets in the middle just X.
Message 14 of 19
hmsilva
Attached revised code...
Hope this helps,
Henrique
Message 15 of 19
zph
That is awesome and works lighting fast!
One more thing if you will, I'd like the portion below modified to be structured so the block names can be changed at the top of the routine.
-changed to something like this-
(wcmatch (vla-get-effectivename blk) titlePage,nextPages)
Message 16 of 19
marko_ribar
Use setqing like you wrote at the beginning of routine and then in the code replace (wcmatch) line with :
(wcmatch (vla-get-effectivename blk) (strcat titlePage "," nextPages))
Don't forget to localize titlePage and nextPages variables in defun of main routine...
M.R.
Message 17 of 19
hmsilva
Revised, but untested...
Hope this helps,
Henrique
Message 18 of 19
zph
Works perfectly and much better than before.
Thank you for your time and expertise, guys!
Message 19 of 19
hmsilva
Glad I could help
Henrique
