Calculate with attributes
jeroendewind
Message 1 of 10
jeroendewind
I've a couple of hundred blocks in my drawing with all manually chosen heights (for example: +1.234). Now the design has changed, so all numbers need to be plussed with the same amount (for ecample all blocks +0.200). Is there a way to do this automatically?
Replies (9)
Message 2 of 10
hmsilva
Hi jeroendewind,
It should be possible to do what you need.
If you do a search in 'Search This Board' for 'add attrubutes' should appear some thread with some similar request.
If not, block name and TAG, it's a dynamic block?
Henrique
Message 3 of 10
jeroendewind
Well, I see a lot of solutions with FIELDS. But the problem is that these things are working like a formula and can subtract and add values of given numbers.
I just want to do come calculation with an old attribute definition to create a new one, keeping my block the same. Not A=B+C, but A(new)=A+200.
Otherwise I have to change my block, add field or more attributes, fill these in, in order to get my new value. More work than just change it manually.
Message 4 of 10
3wood
You can try ALTEXT,
Settings as below:
Message 5 of 10
hmsilva
@hmsilva wrote:
Hi jeroendewind,
Change to your BLOCKNAME and correct TAG...
Untested
(vl-load-com)
(defun c:demo (/ a dz i newval val obj oldval ss val)
    (cond ((and (setq ss (ssget "_:L" '((0 . "INSERT") (2 . "BLOCKNAME") (66 . 1))));<- change to correct
                (setq val (getreal "\nEnter value to increase/decrease: "))
           (setq dz (getvar 'dimzin))
           (setvar 'dimzin 0)
           (repeat (setq i (sslength ss))
               (setq obj (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
               (mapcar '(lambda (a)
                            (if (= (vla-get-TagString a) "TAG");<- change to correct
                                (progn
                                    (setq oldval (atof (vla-get-TextString a)))
                                    (setq newval (+ oldval val))
                                    (vla-put-TextString
                                        a
                                        (strcat (if (> newval 0.0)
                                                (rtos newval 2 3)
                       (vlax-invoke obj "GetAttributes")
           (setvar 'dimzin dz)
    (princ)
Hope this helps,
Henrique
Message 6 of 10
jeroendewind
@3wood wrote:
You can try ALTEXT
[image]
Settings as below:
Thanks, that's what I mean. Tho the software seems a bit suspecious. Do you know/think it's worth registering?
Message 7 of 10
jeroendewind
hmsilva wrote:
Hi jeroendewind,
Untested
(vl-load-com)
           (setvar 'dimzin 0)
                                (progn
                                    (vla-put-TextString
                                        a
                                                (rtos newval 2 3)
           (setvar 'dimzin dz)
    (princ)
Hope this helps,
Henrique
This is too difficult for me, what am I supposed to do? Change TAG or blockname?
Message 8 of 10
hmsilva
@hmsilva wrote:
Hi jeroendewind,
You need to change both
and
Hope this helps,
Henrique
Message 9 of 10
jeroendewind
Wow, that works perfectly!
Thanks a lot!
Message 10 of 10
hmsilva
Thanks a lot!
You're welcome, jeroendewind
Glad I could help!
Henrique
