Visual LISP, AutoLISP and General Customization
writing a lisp to open Acad.PGP directliy with one command
6 REPLIES 6
1805 Views, 6 Replies
hi ,
i want to write a lisp which opens ACAD.PGP file directly,
i write this command but didn't run it to open acad.pgp ,
i don't know where i am wrong..
THANKS in advance..
6 REPLIES 6
hgasty1001
You need quote (double) the file name: (command "ai_editcustfile" "acad.pgp")
Gaston Nunez
markruys2
ALIASEDIT
greg_battin
I think that what you are looking for already exists.
On the Manage Tab > Customization panel and click the PGP button or use the command AI_EDITCUSTFILE as shown in the attached picture.
Or use the ALIAS EDIT command as was already posted...
Dj_T_Rex2002
I figured I'd put my two cents
(DEFUN C:PGP ()
  (startapp "notepad" "C:\\Users\\<username>\\AppData\\Roaming\\Autodesk\\AutoCAD 2014\\R19.1\\enu\\Support\\acad.pgp")
A bit late but this will work also.
(startapp "notepad" (findfile "acad.pgp"))
pendean
in reply to: ChitownCADman
Upgrade it to reload after editing...
(defun c:shortcuts(/ pgpfile)
(setq pgpfile (strcat "notepad " (findfile "acad.pgp")))
(setvar "re-init" 16)
(prompt "\nACAD.PGP...reinitialized. ")
(princ)
) ;end
Forma Design Contest
AutoCAD Beta
