Where to Find the List of Options When Creating an MLeader DStyle
mgorecki
mgorecki
I have lisp code that allows me to create an mleader style, I found it in the forums and it contained a list of options like textheight, scale, etc...
(defun CreateMLeaderStyle (dwg_scale / CMS_MLeaderStyles CMS_NewMLeaderStyle CMS_ColorObject)
 (setq newMlStyleName "Amkor")
 (if (tblsearch "STYLE" "ROMANS")
  (progn
   (setq CMS_MLeaderStyles (vla-item (vla-get-Dictionaries (vla-get-ActiveDocument (vlax-get-acad-object))) "ACAD_MLEADERSTYLE"))
   (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-item (list CMS_MLeaderStyles newMlStyleName)))
    (progn
     (setq CMS_NewMLeaderStyle (vla-AddObject CMS_MLeaderStyles newMlStyleName "AcDbMLeaderStyle"))
     ;(vla-put-ColorIndex CMS_NewMLeaderStyle 256) ;color = bylayer
     ;(vla-put-ArrowSymbol
     (vla-put-ArrowSize CMS_NewMLeaderStyle 4.40)
     (vla-put-MaxLeaderSegmentsPoints CMS_NewMLeaderStyle 2)
     ;(vla-put-EnableDogleg
     (vla-put-DogLegLength CMS_NewMLeaderStyle 5.0) ;Landing length
     (vla-put-ScaleFactor CMS_NewMLeaderStyle dwg_scale)
     (vla-put-TextStyle CMS_NewMLeaderStyle "ROMANS")
     (vla-put-TextAngleType CMS_NewMLeaderStyle 1)
     ;(vla-put-TextColor CMS_NewMLeaderStyle 256)
     (vla-put-TextHeight CMS_NewMLeaderStyle 2.20)
     (vla-put-TextLeftAttachmentType CMS_NewMLeaderStyle 1) ;Middle
     (vla-put-TextRightAttachmentType CMS_NewMLeaderStyle 1) ;Middle
     (vla-put-LandingGap CMS_NewMLeaderStyle 0.125)
     ;(vla-put-ExtendLandToText
    (princ "\n ** Error: MLeader style already exists")
  (princ "\n ** Error: textstyle does not exist")
 (princ)
I have a few questions:
1.  How do I set the General "Color" setting to "Bylayer"?
2.  How do I set the ArrowSymbol to "Closed-Filled"?
3.  How do I enable "Automatically include landing"?
4.  How do I turn off "Extend leader to text"?
Mark
Jonathan3891
Properties for a MLeader style are:
AlignSpace
Annotative
ArrowSize
ArrowSymbol
BitFlags
Block
BlockColor
BlockConnectionType
BlockRotation
BlockScale
BreakSize
ContentType
Description
DoglegLength
DrawLeaderOrderType
DrawMLeaderOrderType
EnableBlockRotation
EnableBlockScale
EnableDogleg
EnableFrameText
EnableLanding
FirstSegmentAngleConstraint
LandingGap
LeaderLineColor
LeaderLinetype
LeaderLineTypeId
LeaderLineWeight
Name
ScaleFactor
SecondSegmentAngleConstraint
TextAlignmentType
TextAngleType
TextAttachmentDirection
TextBottomAttachmentType
TextColor
TextHeight
TextString
TextStyle
TextTopAttachmentType
Jonathan Norton
Blog | Linkedin
mgorecki
hi Jonathan,
Thanks for the list.  Where did you get them?  Do you know where there is detailed information on their usage?
I was trying to set the color to "ByLayer" and I read somewhere to set it to 256, but that doesn't seem to work.
Mark
Kent1Cooper
@mgorecki wrote:
....  Where did you get them?  ....
There are different "classes" of "properties."  For any object that is the last thing drawn, you can get one list from:
(vlax-dump-object (vlax-ename->vla-object (entlast)))
which you can use with VLA-object-based operations, and another from:
(dumpallproperties (entlast))
which you can use with (getpropertyvalue) and (setpropertyvalue) functions.
[Never mind -- that's about drawn entities, not things like Styles.]
Kent Cooper, AIA
mgorecki
Hi Kent,
Thank you very much, that did the trick!!
